possible to repair screen hole? (see pic)
Old 12-03-17, 04:33 PM
can you fix this? patch it somehow?
screen hole along edge https://imgur.com/a/wE8yO
it would be such a waste otherwise being in great condition
Old 12-04-17, 02:40 AM
I doubt it's repairable. Is the screen loose - can it be restretched?
Old 12-04-17, 03:04 AM
I've never heard of stretching screen. can you?
Old 12-04-17, 03:12 AM
If the screen wire is already taut you can't stretch it without damaging it but if it's loose, restretching it might hide the deteriorating portion under the spline.
Old 12-04-17, 03:34 AM
Norm201's Avatar
No! It can't be repaired. Most likely it's old and worn via the sun and weather. It must be replaced. A simple and quick repair. Take it to a Mom and Pop type hardware store (ACE, True Value, etc...) and they will replace the screen and spline. I suggest using fiberglass instead of wire cloth.
Old 12-04-17, 04:51 AM
Screen is so inexpensive I rarely bother trying to re-use old. It's much easier to work with new material.
Old 12-04-17, 05:27 AM
Replacing a screen is a quick and easy DIY project. All you need is an inexpensive spline tool and a razor blade for trimming. Big box stores sell screen kits.
If you have grandkids you get lots of practice replacing screens in doors.
