Go Back  DoItYourself.com Community Forums > Interior Improvement Center > Doors, Skylights and Windows
Reload this Page >
Helping out family member, question on exterior window trim
Old 06-05-18, 02:14 PM
T
Hello, my family member has had someone come in and install a window with nailing flanges in a brick rough opening.
Im not sure what to do. They put 1" trim on the sides of the window but nothing on the top or bottom.
the measurements of each space are :
top 36"w × 3 1/2" d x 1"H
bottom 36" w x 4" d x 5 1/8" H
i have a picture but couldnt figure out the link situation
thanks
Old 06-05-18, 02:53 PM
Received 753 Upvotes on 658 Posts
Welcome to the forums! ,,,, see if this helps
How to insert pictures.
Old 06-05-18, 03:00 PM
T
Heres the pic :)
Old 06-05-18, 03:04 PM
T
Old 06-05-18, 03:08 PM
What was the installer's excuse for not finishing the job?
I assume the side trim is vinyl ? How are the bottoms of the other windows finished? marble or concrete stool? brick up to the bottom of the window?
Old 06-05-18, 03:10 PM
T
@marksr thanks but dont see that option on my phone :)
Ill figure it out though, probably just need to view site from phone in desktop mode
Old 06-05-18, 03:57 PM
XSleeper's Avatar
Received 1,743 Upvotes on 1,567 Posts
Normally you would have a mortared soldier row of brick along the bottom, on edge, set at a 10-15 degree angle. The trim on the sides would normally go on after the brick sill is installed... and the trim would not extend all the way out to the face of the brick like that. It would be 1 1/2 thick at most... ripped as wide as it needs to be to fit between the window and the brick on the sides and top. Then the perimeter would be caulked. Caulk the trim to the brick.... and caulk the trim to the window.
