replace windows help
i have 2 windows that are cracked, the one is pictured and the other is in a florida block home stucco wall
wondering the best way to remove these so i can put the replacements in
Steel frames must be Sawzalled out. Break out the glass... cut each side in half. Pry them out but be very careful not to break the stucco or block. Place wood behind the pry bar to protect the surface.
