help with squeaky weird hinge
Old 10-20-18, 10:31 AM
has anyone seen a hinge like this? i can't find it anywhere. it is squeaking horribly and i have no idea how to lube it. help?
Old 10-20-18, 10:55 AM
XSleeper's Avatar
Received 187 Votes on 176 Posts
It's called a spring hinge... likely a 4x4 spring hinge. Buy WD40 PFTE dry lube and saturate it. If it doesn't help, it could be worn out and in need of replacement.
Old 10-20-18, 03:27 PM
thank you. i'll give that a shot.
Old 10-21-18, 04:30 AM
Received 184 Votes on 171 Posts
I have one of those hinges at my office. The spritz with WD-40 makes it quiet for about a year. Then I just give it another squirt and it's quiet for another year.
Those spring hinges are used where you want the door to stay open or closed. With a Allen wrench in the top and inserting the pin in the side you can adjust the spring tension and direction of the spring action.
