Mortise Lock - wood chewed up in door for screws
I had to remove the mortise lock from the door. Doing so apparently removed what thin wood was holding the screws that held the mortise in place.
Anyone have a solution for this?
I was thinking of using my dremel and chisel to cut some wood out. The opening is 1/2" and goes 3" deep. Anyway, I was thinking excavate, and then put some new wood in there (with some wood glue and maybe two small nails from my nail gun) - that would then give me fresh/new wood to drill.
I don't think there is a magical bondo or wood filler out there - one that would take the weight/stress of a screw, right?
Pictures speak bigger than words. Look at the images below.
Same repair as a door hinge, pick up some 3/8 ribbed dowls, drill out and use lots of wood glue, tap them in place and give a day to dry.
Will be as strong as original!
https://www.doityourself.com/forum/a...1&d=1542094246
You can also stuff it with the wood psrt of one or a few matches. The screw will bite into the wood.
Golf tee, wood match, dowel - I've glued lots of stuff like that into holes over the years; the right piece of wood being determined by the size you need to fill.
Hmm, matches or other filler won’t work (I think).
The picture may not reveal... but if you look close... imagine a circle, the screw goes in the circle... the top screw is missing the bottom half of its circle, and vice verse for the bottom screw. If I put a toothpick in the top hole it falls out, in the bottom I can lift it up. Another analogy, if I put a toothpick in a straw, and removed the top 180/half of the straw, I could lift the toothpick up.
The previous amount of wood here was extremely thin.
I imagine excavate, threw some wood in, and screw the new wood, would be best option?
You have the eyes on the project but I think you get the idea, some form of wood needs to be replaced to give you something to attach too!
