OSI Quad Exterior Only
Old 12-15-18, 01:51 PM
Received 2 Votes on 2 Posts
I just finished doing some interior caulking/air sealing around a couple windows and after finishing I noticed the tube says "Exterior Use Only" on it. What's the deal with this? Is it toxic or something? I'm guessing it should be fine since the areas I caulked will be covered with drywall, correct?
Here's an excerpt from the technical data sheet: "Do not use as a traffic bearing sealant, on log homes or inside occupied structures"
Old 12-15-18, 02:24 PM
P
Received 684 Votes on 631 Posts
I quickly scanned the documents for it online and didn't see and warning against use inside a building.
Old 12-15-18, 02:37 PM
Received 330 Votes on 293 Posts
Basically it just means that the off gassing it does isn't rated for habitable spaces. Shouldn't be an issue especially since you won't be lying down next to it to take a nap.
Old 12-15-18, 02:55 PM
Haha, okay. It does smell really strong right now. I have the windows open.
Old 12-23-18, 06:02 PM
XSleeper's Avatar
Received 721 Votes on 667 Posts
Use OSI Max for interior work if you don't like the odor.
