Go Back  DoItYourself.com Community Forums > Interior Improvement Center > Doors, Skylights and Windows
Reload this Page >
Where can I find these style storm door handles
Old 02-10-19, 01:49 PM
Hi all,
The handles on my storm door took a turn for the worse during the really cold weather - and are stripped. I went out shopping for new handles at Home Depot and Lowes, and found that there were no similar handles, and the ones that were similar looking required the internal mechanism - which our current ones do not. If anyone has seen similar models, or know of other stores that might, I would really appreciate it. Here are a few pictures showing the model I have. The last picture shows that the door doesn't require the internal guts mechanism - and that it's controlled by the inside handle and lower lock:
Thanks,
Rob
Old 02-10-19, 02:04 PM
XSleeper's Avatar
The hinge (or possibly top) of your storm door should have a sticker that shows the storm door brand and model #. If you want an exact replacement, your best bet is to contact the mfg or to use their website links to order parts.
Otherwise, most box stores will sell handles that are similar and that should still work. Filling out your profile completely might help us have an idea of exactly where you live. Not all stores are nationwide chains.
Old 02-10-19, 03:10 PM
Norm201's Avatar
I'm almost 100% sure those are for a Forever door. You need to call Andersen and maybe Andersen they will sell you one. Never can tell with Andersen!
Old 02-10-19, 03:13 PM
XSleeper's Avatar
There is no mortise lock set with this door... this is just a simple 6 hole installation with a spring loaded handle. Replacements may not look exactly the same but will work as long as you get the right type. (not ones for mortise latches/locks)
Here is an example of one:
https://www.swisco.com/Premium-Brass...s_Locks/40-160
Old 02-10-19, 03:26 PM
Thanks all, I was able to find similar aftermarkets online at Anderson Storm Doors. To confirm, the door is a Forever Door. Thanks again for your help, and I've updated my profile as well.
This is the kit I ended up going with:
https://parts.andersenstormdoors.com..._hardware.html
Rob
