Basement exterior door grade
Old 03-12-19, 07:26 PM
Im replacing a walkout basement door. The current door is installed at grade level on the bottom of stairs under a bulkhead, theres a drain on the exterior side.
Should the new door be installed on a curb? What other waterproofing measures do i need to consider?
Old 03-12-19, 07:30 PM
XSleeper's Avatar
It wouldn't be a bad idea. If you have the room, that is. On the exterior, most standard doors will measure 83 1/4" from the bottom of the sill to the top edge of the brickmould.
If you have the room, you could lay a PVC 1x6 down in a bed of polyurethane sealant, then set the door on top of that.
Old 03-12-19, 07:49 PM
Thats good idea.. i also saw some sort of 3 piece pan that is used.
