Garage Door Will Not Open
Old 03-15-19, 09:16 AM
Just bought this house, and I can't get the garage door to open. Trying to manually open, and it won't budge at all. I've looked at the spring, but can't tell if it's broken. The wire coming down from it to the bottom of the garage door is fairly tight. The spring is different than the ones I've seen. Help.
Old 03-15-19, 09:42 AM
check out this page: https://ddmgaragedoors.com/springs/w...on-springs.php It looks very similar.
- Peter
Old 03-15-19, 09:52 AM
Thanks. Checked it out, and also watched several videos. Also called local garage door people, and the cost was $119 to have both side replaced, which seems reasonable. Scheduled for Monday.
Old 03-15-19, 09:54 AM
agree on both sides. they are the probably the same age so if one goes bad the other is probably close behind.
- Peter
