Cannot adjust old door hinge tension
Old 04-28-19, 12:04 AM
I'm trying to loosen the tension on my garage door hinge by following this video, but so far no luck:
https://youtu.be/RPmOioJSJVU
The problem is I cannot rotate the cylinder separately from the hinge; when I put the allen wrench into the hole and turn it towards the wall (counter-clockwise), the hinge also wants to rotate as well, and I'm afraid if I use too much force the hinge will come off the door. Photo of the hinge is attached with door closed.
Here's a video of me trying to rotate the cylinder towards the wall so I can remove the pin:
https://youtu.be/XXqKbNxIJso
UPDATE: I found out the reason I wasn't able to rotate the cylinder was because there was a layer of paint behind the door hinge after it was repainted. After removing that layer of paint, I was able to rotate the cylinder and change the pin position with a little bit of force.
Old 04-28-19, 05:25 AM
Norm201's Avatar
At first I thought you were referring to the bay door. Apparently with your edit, you solved the problem.
