New front door
Old 06-03-19, 04:05 AM
New front door
My son installed new front door. The diagonals from corner to lower corner are with in 1/8 . Yet the bottom rubs a lot.We have tried to lower jam as far as possible which made it better. The space (gasket) on the lower door key side is a little wider than the rest of that side going up the door Any ideas?.
Old 06-03-19, 04:23 AM
Received 74 Votes on 70 Posts
Did he just install a slab or was it a prehung? if the latter, are the sides of the jamb plumb? top level?
Old 06-03-19, 04:28 AM
XSleeper's Avatar
Received 135 Votes on 127 Posts
Put a 3" long screw in the top hinge to raise the leading edge of the door. The screw should go in one of the holes closest to the weatherstripping that you are sure it catches the stud behind the jamb.
