Sliding Glass Door Drywall Return
Old 08-20-19, 09:31 PM
Received 3 Votes on 3 Posts
Thought I had posted about this previously but can't find it...
First pic is looking out, second is looking in. Replacing my SGD and it appears there is a metallic drywall return installed against the studs. I assume this is done for production by the developer.
This one is damaged and either needs replacing or removal. Where would I go about purchasing these? I'm not having luck on searches...not sure of the item term.
Or...do I need to replace it?. How would I finish the the interior without the return.
Previous post.......... Existing-sgd-has-metal-frame-surrounding it
Old 08-21-19, 04:33 AM
XSleeper's Avatar
Received 168 Votes on 157 Posts
I would rip it put and trim it with wood. It's a little hard to insulate the door properly when it's in the way.
Old 08-21-19, 04:55 AM
Received 102 Votes on 94 Posts
If you don't want wood trim you could do a drywall return, I've painted a lot of houses done that way although I prefer the look of a wood jamb/casing.
