Need help making window inserts
Old 08-26-19, 10:44 AM
So I want to make some window inserts. Saw some from a company called Indow Windows but way too much money, like they should be 1/4 of the price. Problem I'm having is that I live in an apartment so I need something I can slide in and out of the window in the same kind of fashion the Indow Window inserts do.
Basically a piece of plexi with a silicone compression tubing around it. Tried looking up all kind of tubing and gaskets but have yet to come across anything close. Figured maybe someone else is good at thinking outside the box on what I could use to maintain an airtight seal.
Also if anyone is knowledgable about all the various option with plexi/acrylic, what would you suggest getting? I want it to be at least 1/4 inch thick (if not possibly go with thicker) and if there is anything that will not yellow over time as I know plexi has a habit of doing that.
Old 09-10-19, 09:39 PM
Nobody around or just nobody has any ideas?
Old 09-11-19, 03:41 AM
B
Received 258 Upvotes on 230 Posts
Have you looked at adhesive backed weather stripping? If wrapped around the edge of insert, will seal on 2 of 3 sides of the perimeter.
Old 09-11-19, 04:03 AM
johnam's Avatar
Received 12 Upvotes on 11 Posts
This might be what you're looking for:https://foamtapes.net/weatherstrippi...ionbundle.aspx
