Go Back  DoItYourself.com Community Forums > Interior Improvement Center > Doors, Skylights and Windows
Reload this Page >
How to seal under an old large heavy wooden door
Old 09-13-19, 03:13 PM
B
Hello all, I'm new here. I have a large wood front door. It's 48" wide and 3" deep. I've filled all the cracks in the door itself. I put a new threshold under the door. It wasn't quite enough though. It sealed a few inches but not all 48". I know I'll need to remove it and plain the door. I'm not looking forward to that. I'm guessing it's in the 200 lbs range. What can I add to the bottom of the door that'll seal it off? The gap is around 1/8 inches.
I'll post some pictures of the door shortly.
Old 09-13-19, 06:36 PM
Norm201's Avatar
Received 356 Votes on 321 Posts
I guess it depends on what you mean by sealing. Do you want air tight or just so the wind and dust cant blow from underneath?
Why not use door sweeps. They come standard 36". buy two and cut one to butt up against the other.
If you're going to remove the door to plane it down, you could put in a groove in the bottom and insert a foam or rubber gasket (similar to garage door gaskets).
Old 09-13-19, 07:15 PM
B
Old 09-13-19, 07:26 PM
XSleeper's Avatar
Received 938 Votes on 856 Posts
Shim the threshold up where it's low, then seal the edges of the threshold.
