Help identifying door manufacturer
Received 0 Votes
I searched several hinge location charts available online and could not find one that matched my door that I need to replace to match other doors. Here are the details.
- Solid core wood grain pattern
- door size 28 x 80"
- 6 raised panels
- slab thickness 1-3/8"
- 3 hinges, 3-1/2" each
- Top of door to top of first hinge - 7", 2nd 36-3/16", 3rd 65-7/16"
- This is an interior door
House is in Chicago area, built in 1987. There is a big "S" on each hinge. No label was found behind the middle hinge on either side as someone suggested.
Can someone please help identify manufacturer?
Thank you
- 6 raised panels
Thank you
Received 0 Votes
I posted a few pictures. I could not edit the original post.
The S reminds me of the Stanley S but that doesn't mean they are Stanley doors. I don't think they make interior doors anymore. It looks like a pressed mdf texture door. Mastercraft (Menards) used to sell nice doors like that back when I started in carpentry but I think almost all their stuff comes on a boat from China and the lots change slightly every few years so there is no matching anything from China, it's all one off.
The S could also be Simpson door company but I know nothing about them. Their infinity line with inlaid sticking looks pretty close.
This might be the closest you will find.
https://www.homedepot.com/p/JELD-WEN...1026/202036884
I doubt you will be able to match it exactly. If you are just replacing a slab, getting the doors unmachined will allow you to match the mortises. You didn't say if you need the slab or the entire prehung.
Received 0 Votes
Thank you for your reply XSleeper. I am trying to replace a bi-fold door on a bathroom with an entire prehung unit like an existing door on another room. I guess I can use a Jeld-Wen prehung from Home Depot. None of the doors I looked at have the nice sticking/edging on the doorstop like in the picture. Stock doors have what looks like a furring strip for a door stop. I will take a look at the links you provided.
One of the existing doors has what looks like a stylized MJ on the hinges (like in one pic). Does that mean anything?
Received 0 Votes
Update:
I looked at the top of the doors I currently have and could make out the word "COLONIST". It was hard to read under a layer of primer. Problem solved! Thank you XSleeper for your suggestions. The ready-to-go Jeld-wen at Home Depot looks like the one, except for the stop. I might replace the stock bull nose stop with colonial. I was more concerned about matching the bead and cove sticking and they haven't changed that in 32 years.
Previous Thread
Next Thread
