Broken door help!
Old 05-02-20, 07:10 AM
P
Received 1 Upvote on 1 Post
Broken door help!
Hi guys,
Hope you are having a productive quarantine and making good use of your time at home. I had some time on my hands last night so I took the initiative to create something that needs to be fixed (see photos).
Can anyone chime in with a clever way to fix the door without having to buy a new one?
I promise my next post will be about a more productive project.
Peter
Top Answer
05-02-20, 10:11 AM
XSleeper's Avatar
XSleeper
XSleeper is online now
Received 1,743 Upvotes on 1,567 Posts
That's pretty far gone.
If you wanted to "attempt" to fix it, you would want to remove the door knob and latch from the door. Squirt as much wood glue (like Titebond) in the cracks as you can... from all sides, from the edge of the door and the edge of the door knob hole. Use a flat toothpick to drive the glue into the cracks by poking it in and out everywhere. Then hold a short scrap of wood (like a 1x4) onto each side of the door, laying it flat over the door knob bores. Then use 2 or 3 C-clamps to squeeze those 2 boards together as tight as you can. Keep the clamps centered on the 1x4. Wipe off any glue off that squeezes out with hot water and a rag. Leave it clamped for 24 hrs.
You dont want the 1x4s to get glued to the door so if you think they might get glue on them and stick, rub some vaseline onto them before you hold them up and clamp them. The vaseline will prevent the wood glue from sticking to the 1x4.
After gluing, you can fill and sand any voids that remain, then repaint. If you used vaseline, you will want to wipe that all off the door with a paper towel, then clean the area with paint thinner before you paint it. If your attempt at gluing fails, then replace the door slab. You dont need a whole prehung door, which includes the jambs.
Old 05-02-20, 07:12 AM
Norm201's Avatar
Received 674 Upvotes on 597 Posts
You forgot the photos
Old 05-02-20, 07:14 AM
P
How do I attach photos? Ty!
Old 05-02-20, 07:49 AM
XSleeper's Avatar
Old 05-02-20, 09:34 AM
P
Thank you! I had to resize it to a smaller resolution also.
I included the picture. What do you think, can it be set flush and painted, or fixed another way?
Old 05-02-20, 10:11 AM
XSleeper's Avatar
Norm201, Peterftw voted this post useful.
Old 05-02-20, 03:09 PM
P
Thank you! That's a great answer.
Tomorrow morning, I will gather those materials and give it my best shot. I will keep you posted with photos of my attempt for your amusement.
Old 05-02-20, 04:55 PM
P
So this is what it looks like now that I removed the knob.
Old 05-02-20, 05:55 PM
Norm201's Avatar
IDK, you can try the fix as X suggested but I doubt it will hold up. After just few slams or closing or pulling it will fall apart.
joecaption voted this post useful.
Old 05-02-20, 07:38 PM
P
Maybe some screws to hold it together?
Old 05-02-20, 07:44 PM
XSleeper's Avatar
It looks exactly the same without the door knob. Get the wood glue and clamps and try it.
Old 05-02-20, 07:45 PM
P
Then slap something like this over it and paint maybe?
https://www.acehardware.com/departme...kFtQ&gclsrc=ds
Norm201 voted this post useful.
Old 05-03-20, 03:23 PM
W
Received 13 Upvotes on 11 Posts
Hi, Try a door sleeve. You need ti know how thick the door is and the back set of the lock.
Good Luck Woodbutcher
Old 05-04-20, 12:21 PM
P
Thank you Woodbutcher. That's the link I posted above. Stay tuned!
Old 05-06-20, 04:00 PM
P
Thumbs up Thank you
It looks like I don't need to use a door sleeve unless this comes apart.
Thanks for the great instructions, Xsleeper! Super easy fix in less than 20 minutes of hand work total!
BTW, I left the clamps on for almost 48 hours. I picked these clamps up at Home Depot for only $5 each. I'm sure they will come in handy again some day. They clamp extremely tight.
Old 05-06-20, 04:01 PM
XSleeper's Avatar
At least if it doesnt last, a door sleeve can be the backup plan. Thanks for posting back with the results.
