Need help identifying this
Need help figuring out what this tab is called and where I can get more.... so I can't upload the pic... it's a tab in the side of a vinyl window that keeps the window channel in place for when you put in the window... it's a plastic tab that holds, then recedes in once the window is put in
In the Reflect site in the link are several types of vent locks....... Sliding window vent lock
It's not a vent lock, it's a sideload take out clip. And as far as I know, they are discontinued. https://www.swisco.com/discussions/C...clips-77-29596
You would probably need to take one out and have it copied with a 3d printer, or switch to metal ones, assuming they would fit your mortise.
The take-out clip is only used to remove the sash or replace the balance. In repairing windows, in a pinch, I put in a screw, in place of the clip, leaving the head out about 1/4" to hold the balance while removing the window.
