Front Door Project
Old 06-25-20, 07:56 PM
T
Received 65 Upvotes on 60 Posts
Front Door Project
Starting the plans to replace the front door. I will demo and prep the opening but have a company do the install. I'm doing the prep because there are certain things I want to make sure is aesthetically correct. For example the wood threshold below the door (slab foundation) currently sits crooked because when they poured the concrete pocket the forms were crooked. Ran into this when I did my sliders.
Anyway, looking to deconstruct the door so I can start. On the hinge side it's easy to figure out how this was installed. On the sidelight side I'm not sure. The nails look like they are behind the sidelight going into the wall framing, which would require the sidelight to go in after the frame was installed. Looking at the pictures does it look like this door was assembled on site? i.e. casement, then sidelight, strike jamb and finally door? The first 2 pics are an example of where they put a shim from both inside and outside. There is no nail head on the outside (determined by magnet).
Old 06-25-20, 09:28 PM
XSleeper's Avatar
Received 1,743 Upvotes on 1,567 Posts
Don't know, but it really doesnt matter how they did it. You typically just run a sawzall around the perimeter of the door and cut all the nails off in order to get the door out.
Old 06-26-20, 01:31 PM
T
I just need to be able to have the ability to reinstall it back while I wait for the new door. I guess I could do as you suggest, then just sink some 3" screws through the jambs to hold it until the new door arrives. Not to concerned about aesthetics of the old door.
Old 06-26-20, 01:33 PM
XSleeper's Avatar
That's a good way to do it.
Old 08-03-20, 07:07 PM
T
So I have discovered that on the hinge side of the door, the wall is perfectly plumb. On the latch side (actually sidelight) the wall is out of plumb about 3/8" inch total top to bottom of door leaning out. This is evident on the outside since one side of the stucco mould is twisted in at the bottom to fit up against the door jamb. The door is also out of plumb (leans out).
I can correct the door plumb on the hinge side by pushing the bottom out, which will allow the stucco mould to line up square, and it will fix the door trim issue on the inside where there was a fat bead of caulk (between the door trim and drywall) at the bottom hinge side.
The other side will be more difficult. How does one align the door when the wall is out of plumb? Is it better for the jamb to be even with the drywall at the top or bottom?
I can fix the outside stucco mould with some carpentry padding, though it will might be visible.
Last edited by Tumble; 08-03-20 at 07:08 PM. Reason: Preplanning, still have current door installed
Old 08-03-20, 07:24 PM
XSleeper's Avatar
It depends on the trim you have but generally it's always better if it's even at the top. The bottom can usually be tipped more easily at the bottom without causing problems.
And typically you are often better off if you just swing the door and observe the gap on the door as it closes, then make slight adjustments on all 4 corners of the door regardless of what is truly plumb based on what that reveal looks like. For example, with a slight 1/8 adjustment in on the top left, 1/8" out on bottom right, 1/8" out on top right and 1/8" in on bottom right you are making what would otherwise be a single 1/2" adjustment.
It's often advantageous to do that rather than have one side be dramatically adjusted. Sure it's great when everything is plumb but when the walls arent you are just creating a problem unless you kind of go with it, or at least split the difference.
