screen door lockset?
Old 07-24-20, 05:51 PM
R
I'm hoping someone can identify this lockset. I'm replacing it for a friend. No brand name on the hardware or door. Help?
Old 07-24-20, 06:27 PM
XSleeper's Avatar
Received 1,743 Upvotes on 1,567 Posts
Looks like a very old Larson or Caradco mortise lock. There are all sorts of aftermarket ones that would probably work. Maybe even one like this.
https://www.homedepot.com/p/Wright-P...15PB/202065847
Measure the distance between screws or take your interior plate with you when you go to the store.
If you want to shop online, check out swisco's site. Follow the links to the product numbers and they have drawings that will give the screw spacing measurements.
https://www.swisco.com/discussions/L...ions-77-159402
By the way, there is a brand name on the latch below the bottom screw. Can't make it out.
Old 07-25-20, 04:02 AM
Norm201's Avatar
Received 674 Upvotes on 597 Posts
Look to me like a an old Forever door (EMCO Anderson)
