Possible to replace rotted wood below exterior door?
Is it possible to replace the rotted wood below my exterior door without having to replace or remove the storm door, toe kick or the door itself? I was planning on having both doors replaced in a couple of years, but was hoping to fix the wood in the meantime if possible. Thanks!
Not really. You have a prehung door frame setting on top of an old fashioned sloped sill. A door on top of the former door sill so to speak. You would need to remove the entire prehung door in order to replace the sill and you would no doubt destroy it in the process.
RickyL
voted this post useful.
And the main reason there is rot there and it's also likely there's more hidden damage behind the siding is that slab never should have been that close to the door opening or siding.
I'm going to make a guess, that siding was installed over old siding.
If this was my job I'd be removing everything down to the bare framing. Removing the siding around the door.
Seeing what was needed to raise that whole door frame at least 1-1/2,
Building out around the door opening so that the new door would not sit recessed in the wall like that, that threshold should have been been sticking out beyond the sheathing by about 1" so that a piece of 1X PVC lumber could have been inserted into the track under the threshold to support it, laying flat on the wall.
At a minimum I'd be using door and window tape around the rough opening, better yet set the door in a sill pan.
Any door I ordered would have PVC brick molding and composite lumber at the bottom of the jambs to prevent future rotting.
The will be a piece of Z molding needed over the top of the brick molding at the top of the door before the siding went back on.
The inside will need jamb extentions made so the jambs come out even with the sheet rock.
RickyL
I did this repair on the 100 y/o house we were renting. The sills for both exterior doors were rotted. I removed the doors and made a sill from PT dimensional lumber. I had to make a filler piece since the originals were true 2" stock. I did both doors in a weekend.
Incidentally, the house had been built by a local shipyard manager. The sills were nailed in place with copper nails so I think they were original to the house.
RickyL
Thanks everyone, I truly appreciate the detailed responses and suggestions. It seems a full replacement is necessary and some additional work to make sure it's done correctly. I will take all this advice into account. All the best!
