Pella sliding doors
Old 09-16-20, 06:50 AM
G
Pella sliding doors
Does anyone know what these are on Pella sliding doors? They slide up and down along the door.
the reason I ask is that there is fog inside the glass but I dont think it is from a broken seal, it looks like there is a panel that can be removed from the frame and the moisture is in between this panel and the exterior glass door. I was wondering if these components were somehow used to remove the panel or release the condensation.
would really appreciate some help if anyone is familiar with this.
Old 09-16-20, 10:02 AM
XSleeper's Avatar
Received 1,743 Upvotes on 1,567 Posts
The long one is like a zipper and it would operate the blinds if you had them. The upper one (and the others like it) pop open the latches that hold the hinged glass panel. Once you pop them all open it will hinge open like a door. Then you can clean the glass.
Slide them along until they stop... that's where the latch is. Then keep pushing them until it pops the latch and it will slide through to the next latch. There are probably 3 of them... top bottom, middle.
Old 09-18-20, 09:16 AM
G
Thank you so much, I only just saw your reply but you are exactly right.
