Prepping concrete threshhold
hi,
I'm replacing the side door in my garage. After removing the old door I'm noticing that the bottom of the rough opening is not at all level.
I just wanted to float my plan out there to make sure I have the right idea
Is this the right way to do it?
Any help would be much appreciated!
- level off the threshold with concrete
- put down a 1x6 piece of pressure treated lumber
- then put down the sill tray that came with the door (using the recommended caulk between it and the lumber
I would grind the concrete so that it is as level as you can get it. If you can't get into the corners use a sandpaper flap disk on your wood to grind it down.
