Exterior door FRAME?
Has anyone found a decent source for exterior frames and thresholds? There are a ton of orphaned steel doors around without mates. Wondering if youve found anything worth pursuing?
Ive built my own before with t&g, metal thresholds and plenty of caulk but would prefer not to!
Thanks!
Thanks!
Most likely your seeing all those doors with no frames is they rotted out at the bottom.
You can now buy prehung steel doors that have a composite material finger jointed into the bottoms of the jambs.
If you also ordered it with the PVC brick molding or bought it as a flat jamb and added your own you would eliminate the weak spot in most ext. doors.
Another thing that is a common cause of steel doors to fail is there most often shipped primed and no one finished painted them with two coats of latex paint.
I'd have to have a whole lot of free time and 0 money to take the time to make up a whole new door frame.
