Go Back  DoItYourself.com Community Forums > Interior Improvement Center > Doors, Skylights and Windows
Reload this Page >
Repairing moisture damage on exterior doors/frame
Old 11-28-20, 11:42 AM
X
I noticed the corners were soft and so I dug in. I chiseled away all the soft wood, now what? I was planning to cut a few pieces of scrap wood and glue it to concrete, calk the gaps on the frame. How do I patch the door? Is there a product that could fill all that volume?
Top Answer
11-28-20, 01:10 PM
XSleeper's Avatar
XSleeper
XSleeper is online now
Received 1,749 Upvotes on 1,573 Posts
PVC is the ideal material to use, since it will never rot again.
Old 11-28-20, 12:06 PM
XSleeper's Avatar
Typically, i would cut some pvc on a table saw for the chunk on the jamb, and cut a kerf for the fin of the weatherstrip to fit into. Then bondo and sand the seam.
On the door, brush it with Minwax wood hardener, and once that is dry, fill the void with bondo. You might want to make a mold to protect the parts of the door that you want to keep clean.
Old 11-28-20, 12:41 PM
X
Hmm, didn't think pvc would apply here.
Old 11-28-20, 01:10 PM
XSleeper's Avatar
cartman, Oberon voted this post useful.
Old 11-28-20, 01:18 PM
X
That looks fantastic, how easy it is to work with without a table saw? I have a hand saw, circular saw and Sawzall.
Old 11-28-20, 01:23 PM
XSleeper's Avatar
You might be able to cut your piece with a skilsaw. Just watch your fingers.
That was is a block of 2 pieces glued together... one was 3/4 thick, the other 1/2" thick.
The groove was cut by running it through a table saw. You would need to do that with the skilsaw.
xxhaimbondxx voted this post useful.
