door striking front of frame
Old 12-14-20, 02:51 PM
R
Where the card is the door is hitting the front of the frame so I have pull on the handle to close the door. What sort of adjustment would fix this?
Thanks
Old 12-14-20, 03:02 PM
Marq1's Avatar
Received 1,145 Upvotes on 1,038 Posts
Two adjustments, get a block of wood and hold it at the point where the door hits the stop molding and give a mild tap or two, it will slightly push the door stop molding. Note, it may break the paint slightly.
Second, completely remove and reinstall the stop with the door in the closed latched position, you will then have to do a little patch and paint!
