Sliding screen door won’t fit?
Old 03-27-21, 11:49 AM
H
I have been struggling with a screen door the previous owners left for us to install at our house. I eventually realized there was no bottom track, and that is why it wouldn’t slide properly. I bought a piece of track for it, but cannot get the door to go in; it almost seems to not. If you see the attached pictures, there is one of the top part of the door on its track, and one of me lifting from the bottom trying to get it over the lip and get it onto the track with no luck.I have loosened the wheels as much as I can, and Lee my measurements, the door should be the right size, is there something I’m missing g? Is the top track not deep enough?
Lifting, cannot get onto bottom track
Gliders are on top track
Top Answer
03-27-21, 04:46 PM
XSleeper's Avatar
XSleeper
XSleeper is offline
Received 1,744 Upvotes on 1,568 Posts
The door probably is aftermarket and just plain doesn't fit. A tape measure would answer that.
Old 03-27-21, 03:50 PM
Tolyn Ironhand's Avatar
Received 708 Upvotes on 601 Posts
Make sure the adjustable wheels are on the bottom. You will likely have to use a screwdriver to push the bottom wheels (one at a time) up in order to get it over the track.
2john02458 voted this post useful.
Old 03-27-21, 04:46 PM
XSleeper's Avatar
2john02458, johnam voted this post useful.
Old 03-28-21, 05:23 AM
I just looked at my patio door and there is no track on top. Just a slot.
Old 05-02-21, 05:09 PM
A
Received 256 Upvotes on 235 Posts
After the wheels are snapped over the bottom rail, both bottom and top wheels need to be adjusted, taking up vertical slack, using the screws in the door side edges. If the screen door corners are capable of scraping the bottom or top of the door frame (the door pitches when slid), they will do so and bind and be an endless frustration when opened and closed.
