How to waterproof window sill near shower.
Old 04-05-21, 05:31 AM
T
Hi,
I wonder if anyone could help. We have a wooden window sill in the bathroom and we need to protect it as we can see that water is penetrating the wood. As you can see in the picture, the sill has rounded edges. What would be the best option in terms of impermeabilizing or protecting the wood?
Many thanks in advance.
Top Answer
04-05-21, 05:38 AM
XSleeper's Avatar
XSleeper
XSleeper is offline
Received 1,744 Upvotes on 1,568 Posts
Wood has no place in a shower...
You can hang a shower curtain in front of it to ensure it doesn't ever get wet. You could also remove all the wood and replace it with cement board, tape and finish it, coat it with Redgard and then tile it.
Old 04-05-21, 05:38 AM
XSleeper's Avatar
marksr, TLondon voted this post useful.
Old 04-05-21, 09:20 AM
Marq1's Avatar
Received 1,138 Upvotes on 1,032 Posts
So we all wood in our bathrooms subject to moisture. Removing and installing a marble/stone sill would be an option, or simply sanding it down, good primer, good paint will help!
Get a good exhaust fan to remove moisture will help greatly!
Norm201, TLondon voted this post useful.
Old 04-05-21, 09:46 AM
Received 35 Upvotes on 33 Posts
All good comments so far. Another option is to sand down the sill to bare wood, coat with a wood petrifier like PC Woody or Abatron, then paint. The petrifier will convert the wood to a hard, waterproof material.
I also recommend removing all of the existing caulk, and re-caulking with a paintable caulk designed for bathrooms. Initially cut the tip of the caulk tube to get a very small hole and get as much caulk into the joints as possible.
Old 04-05-21, 12:37 PM
Norm201's Avatar
Received 674 Upvotes on 597 Posts
Marq and JRsick is what I would also suggest. Many older homes have wood windows in the bath/shower section. Not ideal but not necessary to rip out he sill. You will need to repaint periodically and maintain the integrity of the window.
Old 04-06-21, 12:53 AM
T
Hi. Thank you all very much for your recommendations. I bought the wood petrifier and will prime and paint it. Unfortunately, we cannot remove the sill at the moment but will think about it for the longer term.
Old 04-06-21, 05:01 AM
johnam's Avatar
Received 12 Upvotes on 11 Posts
Looks to me that the sill is cupped or pitched to the outside. Water will sit on the sill if that is the case.
