tips for installing prehung doors
Old 05-07-21, 02:10 AM
Received 754 Upvotes on 659 Posts
While I've installed a few prehungs I've never installed the split jamb type before. I have 2 to install tomorrow. Can you nail thru the stop once you have it plumb/shimmed or will that prevent the other half from sliding in?
Old 05-07-21, 04:56 AM
P
Received 1,846 Upvotes on 1,653 Posts
You can nail through the stop AFTER you have the two halves slid together but not before. I hang the side that has the door. Get it positioned, shimmed and mounted where I want it then slide in the other side's trim.
Old 05-07-21, 04:57 AM
maybe put a few nails thru the casing to hold it in place before you slide the other half in ?
how do you keep the shims in place? force fit or liquid nail?
