Vinyl replacement window
Old 07-10-21, 07:07 PM
K
Received 4 Upvotes on 4 Posts
This is the first time I am doing a major bathroom remodel and this question is regarding replacing the window.
I have removed the trim ( nothing to remove at the bottom, right?)
will remove the 4 screws ( 2 on both sides ) holding the window
what next ?
Do I need to pry out the white strip ( I used a line to point)
Old 07-10-21, 08:13 PM
XSleeper's Avatar
Received 1,743 Upvotes on 1,567 Posts
Once you take all the screws out the only thing holding it will be the caulking on the outside perimeter. Get outside on a ladder and cut that caulk on all 4 sides with a knife and push the window toward the inside, top first. The entire window will come out.
