Hi, I am having trouble finding info on how to repair the framing on the large kitchen window in my home. It is single pane but has framing on the interior and exterior. The framing is damaged on exterior and interior. It's chipped in some areas and the paint is peeling off most of it.
I'm not sure what materials I'm working with or what materials are needed to repair it. On exterior, the chipped areas might be plaster, and the framing itself is wood. On interior the framing looks like it's just wood. I'm a new homeowner and haven't repaired something like this before. Any help/resources you can offer would be greatly appreciated. Thanks! Interior Interior Exterior Exterior Exterior
The interior wood just needs to be scraped or sanded, then primed and painted. The stuff around the exterior side of the glass is called "glazing" (such as Dap 33) and you use a glazing putty knife to smooth it. You can likely find youtube videos on how to glaze a window.
I agree. Your window needs a simple repainting and reglazing. I use a painters tool and wire brush. With the painters tool you can scrape or pick off any loose glazing on the outside of the window. The glazing is sold in caulking tubes and in a tub and I find the tub type easier to work with and do a neat job. Then after the glazing has been repaired you can repaint.
Thank you both so much! Not knowing the materials and correct terms was making it hard to find the right info about repairs. Actually feel like I could tackle this job now (after watching a lot of youtube tutorials). Thank you again!!
I’m replacing several hollow-core interior doors for bedrooms. The jamb is almost a perfect 80x30. So I bought an 80x30 6 panel hollow slab door and I noticed that my strike plate in the jamb is 41” from the ground. So I bored a hole for the doorknob but it was 3-4” higher than the lock block inside the door.
Does the knob have to be in the lock block or can it be higher? Or should I lower the knob to 36” but the drill a new strikeplate hole and patch the old one?
thank you
Hello:
There is 'full-view Glass Aluminum Screen Storm Door at the front side of my house.
Recently, I noticed 'catch/hinge' does not shut tight that happens when closing the storm door from outside, however it's no problem when closing from inside the house.
My son tried to fix to 'shut-tight' jiggling a screw, however it's still the same result.
I'm concerned about this, because it might be 'wreck' storm door when gusty wind 50-60 hits
during windy days.
Is there a way to fix this issue, .... 'shut-tight' both from outside and inside?
Thanks for your advice and suggestion in advance.
