I have to replace the top window pane from an old manufactured home. These windows are basically double pane. Just the exterior. Was broken so I'm going to have that redone. My question would be how hard is it to remove that window frame and then is it equally difficult to put it back in place? I don't want to pull the whole window frame out of the house since that will cause a lot of grief, I just want to have what's broken repaired. Thanks
It's not one of those that are sealed up. In this mobile home there are four panes of glass to on the inside and then the other two on the outside. So I attempted to get some glass today but I measured it incorrectly and ended up breaking the new pane of glass. I'm going to attach photos of my measurements so you can tell me what it should be maybe.
Assuming these are individual pieces of glass you need to remove the molding/stops around the perimeter to be able to remove the old broken glass, then measure that for replacement!
They are individual, I had removed as much as I could without breaking out extra tools and so I was able to get this measurement but I think I'm about a sixteenth too big so ended up breaking the glass.
Does the existing door sill need to be removed along with the door jamb? From the existing door sill to the top of the jamb it measures 80 inches. After the jamb is removed, it'll most likele be 81 or more inches. Does the new prehung door sit on top of the old sill?
Thanks, Joe.
Hello,
One of the seal is located outside of my window. It is broken now. I was trying to buy from HD or Rona. But I don't know the name. It looks like an aluminium product. Does anyone know what's the name and where can I buy it? A website link is helpful.
Thank you!
Fisher
[img]https://cimg5.ibsrv.net/gimg/www.doityourselft.com-vbulletin/1280x959/image_2_45baf117e0fe72f6b27a3e0b0b14383b6ae93824.jpg[/img]
[img]https://cimg9.ibsrv.net/gimg/www.doityourselft.com-vbulletin/960x1280/image_1_979f6eecf2cd415af11b1a07d851aec62e48ecac.jpg[/img]
