Go Back  DoItYourself.com Community Forums > Interior Improvement Center > Doors, Skylights and Windows
Reload this Page >
Help me identify Sliding Window Roller Assembly
Old 08-09-21, 06:33 PM
patrocle's Avatar
I need to replace some of the Sliding Window Roller Assembly and i can find a match anywhere that looks the same as the ones i have.
See attached pictures
Thanks for any help
Looks like is 2.5 inches long, and 1/2" wide
Center wheel to center wheel is 1" 1/8
From hole to hole for the screws is 2" 1/8 (there is only one screw into the window)
overall height is 1/2"
wheels diameter 3/8" (it maybe a little more)
Old 08-09-21, 07:22 PM
XSleeper's Avatar
Received 1,749 Upvotes on 1,573 Posts
You didn't give the roller diameter or how tall it is overall, which is a more critical measurement. You can get several rollers that would work but the height needs to be right.
If I had to guess and pick one that might work, I'd say Strybuc 900-10193.
patrocle voted this post useful.
Old 08-09-21, 08:26 PM
patrocle's Avatar
Thanks for reply.
I have edited first post.
I did buy the Prime-Line Products G 3165 Sliding Window Roller Assembly from amazon, looks the same as the one u pointed out but i still think is not the right one. Looks that maybe needs a little bigger wheels in diameter.
Old 08-09-21, 08:32 PM
XSleeper's Avatar
All that really matters is the height from the base to the tip of the wheel. The primeline one will probably work if the height is the same.
Old 08-09-21, 08:36 PM
patrocle's Avatar
I see,
Will check the height tomorrow as i already installed them.
Thanks for your help!
