We have a pair of external french doors that have a window on either side that runs top to bottom. Each door has a lock on it = four total... One of the four is missing the arm that extends to lock. Was wondering if anyone knows where I can get a replacement?
You could try the following. (Good luck with that)
Manufacturer: Superior Window Products / Div Superior Engineered SWP-1 Address: 1650 Archibald Ave. City, State Zip Ontario, CA 91761 Phone / Alt Phone 909-930-1800 / Years 1998 - 1999
Manufacturer: Storm Weather Products, Inc. SWP-1 Address: 3621 "B" Street City, State Zip Philadelphia, PA 19134 Phone / Alt Phone OUT OF BUSINESS / Years 1985 - 1988
Honestly you should just take one a part and take it to a machine shop and see if they can make you the part you need. Pretty sure you will never find it.
Hello. I installed a new Andersen Frenchwood hinged patio door a few weeks ago. Both panels can open (active/passive).
The frame is installed level, plumb, and square per the instructions. When I try to adjust the hinges, I'm not able to get a gap that is the width of the adjustment hex key (~1/8") like the instructions and video say should be possible. This is on both of the hinge side jambs. What seems to be happening is that I run out of adjustment range on both the middle and bottom hinges and can't push the door out any further.
We've had some rain the past few days and I'm getting some water between the door and oak threshold. The water is coming in under both doors mostly near the jamb. My thought is maybe this has to do with never getting the hinges adjusted the way the instructions specify.
I called Andersen and they suggested that I have the lumber yard I purchased the door from look at the issue in person. The lumber yard does have a door technician and they are willing to take a look but are booked 4 weeks out.
Any suggestions of things to check while I wait? Thanks!
Hi, In last storm, we got water in our basement through window. we have two windows
1.) Well window
2.) Regular basement
There is sumppump pipe cracked right outside or regular small window, pipe we are replacing but what can I do to stop this water entering through window? and pipe is far from well window, so why water came through there?
see pics., caulking would work?
