Storm door gap at the bottom
Old 11-23-21, 02:06 PM
So i recently had a contractor come and install a storm door (36x80 andersen 2500 series) and a front door (feather rivers 36x80 (37.5 x 81.625)
the rough opening of front entry is 40 x 83.
The reason we replaced both doors is because of the draft that was coming in due to our old front door.
and now we have a 2” gap at the bottom of our storm door thats letting leaves in (located in suburban chicago).
we are worried that snow will get in between the storm door and main door once the winter hits.
we are wondering what the best options would be to fix this problem.
the contractor states he cannot lower the storm door anymore due to the lack of space needed for framing around the storm door and that it will interfere with the strength of the framing if we lower it anymore.
his suggestion was to get a door sweep
Old 11-23-21, 02:14 PM
XSleeper's Avatar
Received 1,744 Upvotes on 1,568 Posts
Yeah, that happens when a door made for a 2x4 wall with a wall thickness of 4 9/16" is installed in a thicker wall. You've got more jamb and trim in front of the door sill than your sill is wide. So that moves the storm door out beyond the door sill.
This could have been avoided if he would have gotten a prehung door that was the right thickness for your wall.
It's possible that Andersen might have a 2" sill nose extension for your aluminum threshold... which would close up the gap under the sweep. Other than that, yeah you would need another sweep on the inside of the storm door.
Can't tell for sure cuz I can't see the front edge of the sill.
Old 11-23-21, 02:50 PM
I plqced a temporary adhesive door sweep but there is still openings in the corners still .
you mentioned that andersen may carry a sill nose extender? Would this be on their website?
Old 11-23-21, 02:52 PM
XSleeper's Avatar
You would probably best put the sweep inside. I will see if I can find something out about the sill nose.
Edit: looks like Home Depot sells a kit. I've found that typically these need to be installed before the door is installed, and before the storm door goes on. It's a little difficult to do afterward.
Here is the link. But this really ought to be something your installer should be taking care of. This is elementary door installation stuff.
https://www.homedepot.com/p/Feather-...60DZ/100097884
The sill nose extension is 2" wide, so if your storm door is more than 2" away, it may not be enough to help.
Old 11-23-21, 03:17 PM
Thank you!
the contractor is stating that since the door is installed correctly that he no longer has any part in it and would need extra pay to do any additional work (he wanted to charge me $200 to reinstall with more wood at the top to cover the gap at the bottom which he couldve done to begin with.)
i would say its unfinished. Or incorrectly installed.
Old 11-23-21, 03:19 PM
XSleeper's Avatar
If it was installed correctly there wouldn't be a problem with the storm door sweep. And he knows it.
Old 11-24-21, 12:23 PM
badeyeben's Avatar
Received 54 Upvotes on 48 Posts
Maybe you could glue a piece or two of vinyl trim (PVC) under the door. Down on the concrete not on the door. Maybe at least get close enough to fill most of the gap and then the door sweep would handle the rest. You would need to seal around it with silicone caulk to keep weather out.
Old 11-24-21, 12:37 PM
2
Received 336 Upvotes on 288 Posts
If the contractor is an Andersen certified installer contact the manufacturer.
