I need to replace a "sidelight" window which is the leftmost window on the first picture below. It is a casement window.
The opening has three windows: two sidelight casement windows and a single hung window. The middle window is wider, so quite standard and would be fairly easy to replace.
I am not sure I can find a window that is narrow and tall like the existing one. A stationary panel, or a picture window would be OK.
This post is about the approach, level of skill that is required and type of window that would work. Any ideas regarding how I should proceed?
It's not an easy question to answer when we can't be there in person to look, poke and prod, or measure. You kind of need to figure out how much of the "trim" around the sash is removable, as a "stop" is typically a removable seperate piece... but not always. Your goal is just to try to make the opening as big as possible without tearing into the "main frame" of the window. Once you know that size, then you can get the biggest window that will fit, since maximizing glass area is always desirable.
As far as sash replacement... yes and no. No, because most guys will look at you with a blank stare and have no idea what you're talking about. Yes, if you get just the right person who understands what you are after. And yes and no, because IF you can get a sash (preferable because it maximizes glass area since a sash-only has no "main frame" around it)...you would likely want it to be fixed, not operating, to avoid the hardware and weatherstripping problems you would encounter in trying to retrofit a new sash into an old window frame.
...OR, if you want more of a traditional like-for-like sash replacement, you could have an exact replica of your existing hinged sash made, and install it as-is. But places that still do that are getting hard to find. And it's not cheap.
So you could go a whole lot of ways with it... and its hard for us to suggest one or the other.
The drawback of just putting a custom sized fixed vinyl replacement window in that opening is that the glass area would be reduced by the vinyl frame plus the frame of the sash inside it. So much reduced that I think you would be really disappointed. (I've heard people complain about this before) For example, if you measure your clear glass opening now and it's maybe 14" wide, a fixed vinyl replacement window might have a clear glass opening of 10 or 11". Because there is a lot of vinyl frame. So its quite a sizable difference if you compare the glass area before and after. When people don't know that going in, they can be a little upset when they see it at first.
So i recently had a contractor come and install a storm door (36x80 andersen 2500 series) and a front door (feather rivers 36x80 (37.5 x 81.625)
the rough opening of front entry is 40 x 83.
The reason we replaced both doors is because of the draft that was coming in due to our old front door.
and now we have a 2” gap at the bottom of our storm door thats letting leaves in (located in suburban chicago).
we are worried that snow will get in between the storm door and main door once the winter hits.
we are wondering what the best options would be to fix this problem.
the contractor states he cannot lower the storm door anymore due to the lack of space needed for framing around the storm door and that it will interfere with the strength of the framing if we lower it anymore.
his suggestion was to get a door sweep
[img]https://cimg8.ibsrv.net/gimg/www.doityourselft.com-vbulletin/2000x1504/ba28be0d_c485_4994_812a_260a4e206d0f_88cd238df727fdf05eb53b194ce05309059f86ca.jpeg[/img]
[img]https://cimg0.ibsrv.net/gimg/www.doityourselft.com-vbulletin/2000x1504/de318692_9766_49c2_b5f6_cae7d1ffaf08_77331b56049b7da347d494db5651d566a0e6e5a7.jpeg[/img]
My 14 yr old house has two doors with some rot issues. One is a 32" single opening side garage door with some jamb rot and the other is a double opening french with 36" doors with jamb rot and bottom rail rot on one of the doors. They're both exterior rated fiberglass with wood jamb/casing manufactured by Thermatru. The french door is on a patio and under roof, the other single is a side entry as shown in the photos. Thermatru warranted the lost argon seal in the windows but said the rot was not part of their warranty (disappointing to say the least).
Two questions:
1) Has anyone tried to cut out jamb rot (like as shown on both doors) and added a filler piece and sanded painted etc.? The wood seems to be solid above the rot in the jamb.
2) Relative to the french door bottom rail rot; Can i clamp that up and fill it with some gelcoat or bondo or something and sand smooth paint?
I'd like to try something short of ripping these two doors out. They are the only two that have rot out of 10 doors with this issue (4 of the other french doors windows lost seal but they warranted that).
Looking for suggested methods and materias to use/patch/glue
[img]https://cimg2.ibsrv.net/gimg/www.doityourselft.com-vbulletin/2000x1538/thermatru_door_and_casing_rot_14e880966851f2babcaaf337942639b7148687b6.jpg[/img]
[img]https://cimg3.ibsrv.net/gimg/www.doityourselft.com-vbulletin/2000x1550/thermatru_door_casing_rot_6741b0dde049760b4ab2ce9edd902e5bb88c151e.jpg[/img]
l and any other recommendations.
Thanks! FF
