Need new bathroom door
Old 01-21-22, 07:53 AM
N
Received 1 Upvote on 1 Post
We need a new door to our bathroom (long story short, someone (not me) tried changing the door from outswing to inswing, and it never quite fit right/trim is a mess...).
In any case, I'm going to have it done by a pro this time (sorry, I know this is a DIY forum) and I found a door I like, but I want to make sure I order it correctly (LH vs. RH, etc.).
I also can't tell the difference between these two other than Mission vs. Equal in the name. All the pics seem the same. Any idea what the difference might be?
https://www.wayfair.com/home-improve...085%2C46869883
https://www.wayfair.com/home-improve...097%2C46869885
I know we need 24 x 80, and I was told to order it with a jamb and lockset cutout, which I believe this/these wayfair door(s) includes.
I'm a little confused by LH vs. RH as I never know if that means looking in from the outside or being in the bathroom looking at the door.
If looking from hallway into the bathroom, the door opens in to bathroom, with the hinges on left (inside the bathroom).
From inside bathroom, handle would be on left, and hinges on right.
Below are pics from inside and outside. Please confirm if I should order a LH or RH door.
Alternatively, is it better to go into HD and order in person, show them pics, etc. to make sure it's correct. This door is fine for us as well: https://www.homedepot.com/p/Steves-S...ELHN/306157390
Thanks!
Looking into bathroom from hallway:
Looking out from inside bathroom:
Old 01-21-22, 09:00 AM
Marq1's Avatar
Received 1,137 Upvotes on 1,031 Posts
If what you are showing is the correct swing you are looking to buy it is a LH door.
Old 01-21-22, 09:08 AM
N
Perfect, thank you!
