Go Back  DoItYourself.com Community Forums > Interior Improvement Center > Doors, Skylights and Windows
Reload this Page >
White dots forming in between double pane window. What is it??
Old 01-22-22, 04:09 PM
Hello it looks like there’s some white dots looks like maybe mold forming in between the double pain windows how do I fix this or is it something I need to replace the window for??
Old 01-22-22, 04:20 PM
XSleeper's Avatar
Received 1,749 Upvotes on 1,573 Posts
It means your double pane IGU needs to be replaced. Typically this is a job for a commercial / city glass shop. If you can take the sash out and take it to them to measure, it will likely cost you a little less than if they have to send someone out to measure it.
They will have to make the new IGU which takes a week or two, depending on how busy they are.
Oberon voted this post useful.
Old 01-23-22, 08:26 AM
2
Received 337 Upvotes on 289 Posts
How old is the window. It might be covered by a manufacturer's warranty. Some windows have manufacturing dates on the metal glass separator between the panes.
Old 01-23-22, 10:01 AM
this window is less than 2 years old. it came installed in my new construction build. surprised that it would have issues so soon. i contacted the manufacturer to see if they can cover via warranty.
can someone confirm if this is mold or something else?
Old 01-23-22, 10:11 AM
XSleeper's Avatar
It's the moisture affecting the clear low e coating on the inside of glass. The stain cannot be removed.
Old 01-23-22, 10:45 AM
O
Received 12 Upvotes on 9 Posts
If only 2 years old it should be covered under warranty, Do you know who manufactured the window?
Old 01-23-22, 04:26 PM
Received 1,198 Upvotes on 1,153 Posts
I don't know why you can't accept X's answer - this is not mold.
Old 01-23-22, 08:39 PM
Received 48 Upvotes on 41 Posts
http://www.premierglassfl.com/glassandmirrorpros/what-is-an-insulated-glass-unit-igu/ describes the problem.
