How to fix a window grill?
Old 01-26-22, 11:10 AM
B
My exterior doors have what looks like plastic window grills on them that the previous owners took the middle crossing bars out leaving the frame with gaps. I would like to somehow fill it with the intention of painting the whole frame afterwards any suggestions?
Old 01-26-22, 11:22 AM
badeyeben's Avatar
Received 54 Upvotes on 48 Posts
A paintable caulk would work.
Old 01-26-22, 11:26 AM
Marq1's Avatar
Received 1,138 Upvotes on 1,032 Posts
Filling the gaps and painting or re-installing the cross bars and painting?
Old 01-26-22, 11:31 AM
P
Received 1,846 Upvotes on 1,653 Posts
You could replace the trim. It would be four pieces of molding... without the holes for the grill pieces.
You can fill the holes with putty. You can also use painters caulk though for a big hole like that I would let it dry for a couple weeks before painting.
Old 01-26-22, 12:02 PM
Received 754 Upvotes on 659 Posts
While caulking will adhere well in a hole, it will shrink and never look as neat as painter's putty will.
