Broken sliding door
Old 03-10-22, 06:22 PM
E
Broken sliding door
Hi all,
​​​​​​Just trying to fix my sliding door, I believe the screw needs to be frightened to raise the wheel the door slides on. Unfortunately i can't do it as the door is broken and the screw doesn't have support to tighten against. Have attached a picture. Anyone got any suggestions? Not the best with handyman stuff haha
Old 03-10-22, 06:52 PM
XSleeper's Avatar
Received 1,744 Upvotes on 1,568 Posts
If it won't adjust you probably need to get new rollers. The sliding panel comes out and lay it on its side, then take out a roller and post a photo if you can't locate a matching roller.
Old 03-11-22, 03:27 AM
Received 266 Upvotes on 238 Posts
You could try a washer under the screw.
Old 03-11-22, 05:02 AM
XSleeper's Avatar
Oh, if the problem is no backing for the screw, yeah a big fender washer, or get some flat aluminum stock from the hardware store, cut a piece about 3" long, drill 2 holes in it, then back out both screws and put the aluminum on as a patch.
Old 03-11-22, 06:13 AM
E
Thanks for the suggestions. And yeah it's because there's no backing I can't tighten it properly. Will try with a washer but will have to make my own as the head of the screw is small and the area it needs to cover is quite a lot.
Thanks for your help
Old 03-11-22, 06:18 AM
XSleeper's Avatar
That's why a "fender washer" would be used. Large washer, small hole.
johnam voted this post useful.
