Go Back  DoItYourself.com Community Forums > Interior Improvement Center > Doors, Skylights and Windows
Reload this Page >
Shifted sagging glass on entry door with side lites
Old 03-11-22, 12:57 PM
Received 2 Upvotes on 2 Posts
Fiberglass doors, original to home which is about 13 years old. MMI brand, maybe PlastPro?
Have noticed that the glass in the doors has shifted lower considerably. In some cases you can see where the frame has moved, in others where the glass seems to have dropped inside the frame (both situations visible in the attached pictures). ​​​​Was intending to paint soon, but I'm concerned I have a bigger problem to deal with first.
Common issue? Any fix other than either replacing the glass or fully replacing the doors?
Thanks!
Old 03-11-22, 01:07 PM
XSleeper's Avatar
Received 1,744 Upvotes on 1,568 Posts
No, I wouldn't say it's a common problem... probably specific to that brand and their design/engineering. About all you can do is try to clean what old sealant you can and then recaulk before painting and hope that it's done moving.
Old 03-11-22, 02:48 PM
Thanks. I was particularly concerned about the glass which looks like it has shifted downward in its frame, which is different than the whole frame moving.
Old 03-11-22, 03:03 PM
Marq1's Avatar
Received 1,137 Upvotes on 1,031 Posts
I've got, and have had, similar Fiberglass/steel doors. The glass insert usually sit on some pins that are part of the moldings on each side of the window that support the glass when they are screwed together.
Not really a a big issue other than it may need to be taken apart and reset so the insert doesnt sag.
johnam voted this post useful.
