Entrance door cracking plastic Sill Cap replacement
Hello, The plastic/ vinyl sill cap on my entrance door aluminum threshold is cracked / damaged. I would like to replace it but could not find any alternatives as this sill cap seems to be of non-adjustable type or pretty much comes with aluminum threshold. (Pic attached for reference)
So i was wondering, if anyone can help me with the following 2 questions:
1. Can i replace this cracked plastic/vinyl sill cap with an adjustable one? if yes, how would determine the size of new adjustable sill cap?
2. if this cannot be replaced with an adjustable one then where can i buy plastic/vinyl replacement sill cap? any guidance on how determine replacement sill cap width + length will be very helpful.
Thanks in Advance.
Kaul
Reason: reoriented pic
Yes that is the one broken / cracked and need replacement. I know i could it out by taking the 1/4" round and then just peeling it off. But i could not find where to find replacement either in Plastic/Vinyl or my preference will be wood or metal (adjustable) - so it doesn't brake again. Thanks for your help.
Thanks for your reply and i am ok with trimming it - as long as i get the right replacement product.
After looking closely at the product, I don't think it matches what is currently installed. This product has a flat top, where what is currently installed has almost 2 vertical edges with holes - used for draining water towards outside.
On top of that i am also not sure about the size, especially the width on the top so it just goes under and until where the door closes.
I don't have any pieces as it was installed by a contractor and at that time, I didn't knew that sill cap can either be wood/metal/vinyl/plastic and adjustable.
I only looked it up once it cracked.
I will see if i can take it out safely (without damaging it any further) to get a side profile, which should give better understanding of what the replacement should looks like - with dimensions.
2 Questions:
1. If I take out out the plastic sill cap and not replace it for sometime (while i look for alternatives), does that mean there will be air draft from underneath the door?
2. Can i replace plastic sill cap with wood adjustable wood sill cap without replacing the aluminum threshold - as that will be a lot of work?
Any help / suggestions are much appreciated.
Thanks
Have a nice day!!
I am helping install a new 32 in an exterior door. Before I unpacked the door I measured the angles meaning top left to bottom right. The difference between the two measurements is 3/8 on an in. I feel the door is not square, to begin with, and wonder if we should send it back? Any ideas?
I had a church Outreach group come help me with trying to get a door put into my back patio. I noticed that the door extended inside leaving about an inch or so exposed. I think this door was meant for a 2x6 frame and not 2x4. As you can see from my photos there is nothing exposed outside and it's pretty much flush with the siding period I'm planning to put vinyl siding up. My question is what do I do on the inside there so that I get rid of that? I thought about just putting another sheet of drywall up on that wall it's not that big and I already have to make major repairs to the wall.
[img]https://cimg4.ibsrv.net/gimg/www.doityourselft.com-vbulletin/2000x901/20220604_095923_a8f4426cf3d2254b77cd6591ab5592b462eee89f.jpg[/img]
[img]https://cimg2.ibsrv.net/gimg/www.doityourselft.com-vbulletin/2000x901/20220604_095914_cdee7c0f46157bdd756df11dfff8500aa634b816.jpg[/img]
[img]https://cimg7.ibsrv.net/gimg/www.doityourselft.com-vbulletin/2000x901/20220604_100155_02f13e67f67333becf43915028bdc3efd42fdd52.jpg[/img]
[img]https://cimg6.ibsrv.net/gimg/www.doityourselft.com-vbulletin/2000x901/20220604_095838_661c7f38a5849e37c18283f388e333e183baea36.jpg[/img]
