Hinge on door correct or not?
Old 08-07-22, 01:15 PM
L
Received 8 Upvotes on 8 Posts
The garage door needs to be replaced to sell a house. Is this hinge installed correctly or should it have been chiseled into the door. I need this done quickly and cheaply and even though it's not the right way maybe I was just wondering if I could get a 32x80 exterior slab door and since it was built like this already I don't know why I cant do it again. Or maybe it's correct?
Old 08-07-22, 01:35 PM
XSleeper's Avatar
Received 1,743 Upvotes on 1,567 Posts
Some doors come that way from the factory... often cheap box store doors. Mortising it will increase the gap on the latch side so if it closes fine its not a problem.
Old 08-07-22, 03:10 PM
L
So how about an interior bedroom door. It measures exactly 30x80 so I'm assuming it direct replacement would be very easy. Current bedroom door has peeled away and would just take a crazy amount of effort to make look better much easier to buy new and I don't mind chiseling the hinges because that will be easier than trying to glue door together
Old 08-07-22, 03:27 PM
XSleeper's Avatar
Typically door hinges are mortised, yes.
