Go Back  DoItYourself.com Community Forums > Interior Improvement Center > Doors, Skylights and Windows
Reload this Page >
How do you properly fasten a exterior prehung door to a brick opening
Old 08-22-22, 06:07 AM
R
I have a older brick house. I brought 2 fiberglass entry doors. I removed the first old door and the opening had 1 inch thick and 3.5 wide wood attached to the brick. I screwed the new door into the wood and the install was a success. When I remover the 2nd door the wood attached to the brick was rotted. I installed a new piece of wood screwed into the brick but it is not setting flush against the brick. which is causing the new door not to seat properly. Should I remove the wood pieces and grind the brick to make it flush and then put back the wood and install the door or would it be best to remove the wood completely and try screwing the new door directly into the brick? Thanks in advance.
Old 08-22-22, 06:51 AM
Received 759 Upvotes on 664 Posts
could you use a thinner piece of wood and then shim it to fit? or notch the wood?
Old 08-22-22, 11:19 AM
R
No a thinner piece of wood won't work. there is more brick sticking out towards the middle and bottom which make the top section of the wood stick out. instead of using the wood as a whole piece maybe I could cut it in sections to make it work..I might try chisling the brick to try and get it close to level.
