Wood door glass insert removal
Old 09-13-22, 12:07 PM
How do I remove the glass, I took the moulding of one side.
Don't want to damage the moulding on the other side.
See pictures
Thanks
Top Answer
09-13-22, 02:25 PM
XSleeper's Avatar
XSleeper
XSleeper is offline
Received 1,745 Upvotes on 1,569 Posts
It's likely "glazed" to one side with silicone. If that silicone squished around the sides of the glass you will have a real hard time getting it out. A pro would use a deglazing knife, some are like a thin putty knife that is sharp on the edges. Others are more like a pizza cutter with a good handle to grip and push/pull. Suction cups would also help, to have someone pulling on the glass while the other guy cuts. But you might be able to accomplish the same thing by flipping the door over, place a cushion beneath it (like foam board), and that way you could cut the perimeter while you push down on the glass with one hand from above.
Tempered glass is pretty hard to break, but as mentioned, prying on the edges is not smart... that's where it's weakest.
Old 09-13-22, 01:01 PM
P
Received 1,849 Upvotes on 1,655 Posts
Now just remove the glass... without breaking it. The "glazing"/caulk should be the only thing holding it in place.
Old 09-13-22, 01:09 PM
2
Received 336 Upvotes on 288 Posts
Slip a thin putty knife between the glass and the wood moulding to loosen it from the glazing compound/caulk. Do not try to pry the glass away from the wood with any force. That will break the glass.
Old 09-13-22, 02:25 PM
XSleeper's Avatar
2john02458, johnam, Oberon voted this post useful.
