Weatherstripping Wonít come out of kerf
Old 10-14-22, 02:12 PM
Iím trying to replace the weatherstrip but itís literally pulling away from the Kerf leaving the material in the kerf. I tried to pull it out with a small flat head and using needle nose plyees but itís in tight as if they installed The frame around the weatherstripping
Old 10-14-22, 02:47 PM
XSleeper's Avatar
Received 1,642 Likes on 1,470 Posts
My guess would be that it's old enough that it isn't a kerf per se. The wood stop may be removable and it's nailed over the top of it. Would need a photo from farther back to have a better idea what we are looking at
Old 10-14-22, 02:48 PM
My thoughts too. The weatherstripping is clearly in the groove. Can I just remove everything and leave the excess flush to the groove and replace with a stick-on weather stripping (e.g. non kerf)?
Old 10-14-22, 03:28 PM
XSleeper's Avatar
I wouldn't even recommend stick on weatherstripping for a doghouse.
Old 10-14-22, 03:42 PM
Only weatherstripping is one with a kerf?
Old 10-14-22, 06:03 PM
XSleeper's Avatar
You can get the kind that are attached to an aluminum extrusion, and screw them on.
The following users liked this post:
