what material is this kickplate?
Old 03-13-23, 08:57 AM
Received 1 Upvote on 1 Post
Our exterior door has a kickplate. When I put a magnet to it, there is no attraction. I notice that the screws holding it on are starting to rust. What material is the kickplate likely and what type/material screws should I get to prevent them from rusting again? Thanks
Old 03-13-23, 09:19 AM
the_tow_guy's Avatar
Received 213 Upvotes on 170 Posts
Could be stainless steel which is not always magnetic. Stainless steel screws would work and won't rust. You might trying scratching it with a knife blade on the edge to see if it's soft like aluminum.
Old 03-13-23, 10:35 AM
P
Received 2,014 Upvotes on 1,806 Posts
Your kick plate is most likely stainless steel though there is a slight chance it's brushed aluminum. Either way stainless steel screws would be the best.
