Hi!
I took a hollow luan door off the frame and changed out the hinges with new ones and painted the door frame.
The door now binds a bit near on the vertical near the top on the latch side of the door. The bottom vertical area has clearance.
I made sure the screws are in flush, tight and the hinges fit into the existing door and door frame mortices.
Maybe there's a little extra paint in the mortise of the frame? The new hinges are a hair thicker than the old hinges?
Before I start chopping and doing things wrong, I figured I'd ask the expert here : )
Would you take the top hinge off and chisel out a little on the door frame mortise? Any tricks to make sure I level the entire mortise area? Just practice and skill?
It depends. Close the door and look at how much of a gap you have between the door and the jamb on the hinge side at the top hinge. If you have 1/8" gap there, you could mortise that top hinge just 1/16" deeper. But you could also shim it. You'd remove the jamb screws on that top hinge and put a thin slice of cardboard (like maybe 3/8x3 1/2) vertically in the mortise on the side that is closest to the doorstop, then screw the hinge down on top of it.
Admittedly it's a trivial question. But it irks me that the manufacturer / retailer don't tell you the answer.
Bought some hinges for interior doors in the house. They each came with 7 screws. 6 shorter and all the same length. the 7th is longer.
What to do with the 7th? I figure you can use that if you are hanging a heavy door to help keep the hinge from pulling out? You'd put the longer one in the top hole in the door frame?
But the instructions don't mention the 7th. calling their customer disservice number, it answers 'thanks for calling lowes' so it's their private brand? And they will call me back in 26 to 49 minutes 'cause the que is long. I bet the person will have no clue.
Going to the lowes website and searching on the 3 different numbers on the bag get nothing found.
1) Am I right about how to use the long screw?
2) How do you move past stupid things like this - you buy something and questions can't get answered? I have OCD and waste time trying to get answers.
[img]https://www.diychatroom.com/attachments/2023-04-05-11-47-51-jpg.738058/?hash=25a648672ae48f742f09b55c608b52c0[/img]Read More
Hi,
I am a newb at replacing windows. I did replace my kitchen window a two years ago, but that replacement was also a resizing, so I was much more flexible with picking a size for the window and I reframed it on the outside and inside.
This time, I am looking to remove an existing repcacement window:
[img]https://cimg2.ibsrv.net/gimg/www.doityourselft.com-vbulletin/640x480/img_2084_14d20a8fc1f7bc7ef4c08d4166e6688c7655cf21.jpg[/img]
[img]https://cimg4.ibsrv.net/gimg/www.doityourselft.com-vbulletin/640x480/img_2088_8386f5b11f1c9d2fc7e6833b330669f1c3fa6f02.jpg[/img]
So I measured that the width of the new one needs to be between 29'' and 30'' and height 36''-37''. I would not fit if more in any direction and it would create gap with outer frame if less.
So those are my margins. But my problem is that I cannot find a replacement window with that size! I have tried Home Depot and Lowe's. Do you have any other suggestions??? Online searches yield no good results so far.
Thankful for any advice!Read More
