Go Back  DoItYourself.com Community Forums > Interior Improvement Center > Doors, Skylights and Windows
Reload this Page >
How do I eliminate Moisture between double pane insulated windows
Old 07-11-01, 07:24 PM
Guest
Question
I have a problem with moisture inside the insulated windows. How can I eliminate this problem. It is so bad you cannot see clearly through the window. There are 2 panes of glass with an air pocket between them and moisture forms between the panes.
Old 07-11-01, 10:05 PM
L
Received 1 Upvote on 1 Post
That moisture is ther because the seal of the glass is broken. The only way to fix it is to replace the Insulated Glass (IG) unit. Call a glass shop. They will have to come measure the unit (unless it is the sliding sash, which you can take to them) and order a new one for you. Should take about a week to get the new unit and about an hour to have it installed.
