Old Pella casement window
Old 08-21-23, 02:53 PM
T
I have a 1979 Pella casement double window, each with two panes of glass and a tiltable "slim shade" between them. I broke the inside, removeable glass pane in the left window. Pella does not stock these window panes. Local glass company won't touch it because of the rubber/metal edging to the glass with moveable clips to hold the pane in place and the plastic knob in the lower right corner of the pane which controls the tilt of the shade. Any ideas other than getting a new casement window put in?
Complete inside view of casement window
Left inside glass pane is broken
Old 08-21-23, 03:01 PM
XSleeper's Avatar
Received 1,845 Upvotes on 1,660 Posts
Your best bet is to contact your local Pella dealer or their service department online. Ask if a replacement DGP is available. If your blinds are glued to the DGP, you are likely out of luck as they don't make those any longer. You'd need to get a new sash. Not the whole window, just a new sash with blinds.
