Bottom of door not closing properly
Old 09-12-23, 03:11 PM
P
When attempting to close the door to the bathroom the top part closes before the bottom half, requiring the bottom to be pushed in in order to be closed properly. Any ideas how to fix this issue?
Pictures are of the bottom, top, and handle when closing the door without forcing the bottom shut.
Old 09-12-23, 03:54 PM
XSleeper's Avatar
Received 1,845 Upvotes on 1,660 Posts
I assume the other 2 corners of the door that aren't pictured are flush like the top right corner is?
Old 09-12-23, 03:55 PM
B
Received 275 Upvotes on 245 Posts
Use a level to verify door jamb and stop are plumb. If not, fix. If plumb, assume wooden door is warped and need to be straightened. Remove door from hinges and clamp to flat surface with high corner sticking up and unsupported. Place weights on high corner until it straightens. Check in 2 days. If not flat add more weight and check in 2 days. Repeat until flat. If flat, rehang the door. No guarantee it won't warp again. If it does, would consider replacing with a composite door.
Old 09-12-23, 04:27 PM
P
Other corners are indeed flush like the top right corner.
The door jamb and stops are plumb. It doesn't look very warped to my eye but I will try and flatten out door and see if that helps. Thank you!
